Hi all I am having a problem connecting UGS to easal. during the busy part of the day I am not able to connect after hours I can connect . I suspect that the broadband is overloaded. anyone have this problem
Can you elaborate on this:
Don’t you save the gcode file and then open that with UGS?
All of the Easel processes (other than the tools and the design library) can be done with the PC offline, so I doubt that it’s a network issue…
I’m actually able to login, then turn off all networks and I can import SVGs alter the design, make toolpaths, save the gcode and even carve from within Easel all while the PC is completely offline.
