Can you uncombine something that you have combined? I have a set of four stars that I combined that I could like to uncombined? Any suggestions?
Thanks, Letha
Thanks, Letha
Check out the Xploder App in the App section of Easel…
{:0)
Brandon Parker
You can undo which is cntlZ BUT it has to be while it is still live and you will undo everything you did after it if that makes sense. It best to use Xploder APP
Easel Combine dont group, it merge them into one object. Therefore there is no un-group function sadly, because the combined objects have no history once combined.
The Xploder app do work but it break the object into several individual objects, an “i” for instance is exploded into two individual objects.
