Hi,
I’m trying to do undercut with Easel, but i can’t find any bit or option in the software. Do i have to conclude that Easel can’t do undercut??
Hi,
Easel can create various 3 axis cnc movements that may, in some instances, create a desired undercut. An undercut would be moreso a result of the bit selection though… and you may need to lie to easel as to which bit is being used to achieve the desired cut path to accomplish the desired undercut end result… However, you are correct in that easel is not really designed to achieve undercuts.
Thank you SethCNC.
My undercut is more complex than linear cut. So i think i need another software.
