First day carving with Easel and X Carve.
Carved three three signs without a problem
Attempts 4,5 and 6 I had it set and designed to carve 20 inches wide but it started at the appropriate zero but shrunk it to 16. Same with the top, but worse. Instead of ten, it only carved 6 inches and skipped eveything in those last four inches and said carving complete.
This sounds like your $100 and $101 are not set correctly
You can go to machine>General settings>machine inspector and read the settings of your cnc.
Here are the default values to check to.
So helpful. Thank you.
