I still. trying to figure out carve and I would like to cut out the USA with either options which I will attach. I uploaded the USA to a SVG , however I cannot make the outter perimeter of the USA cut completely through 1/4 plywood but just engrave each states or the other option is to use a 3ft by 2 ft 1/4plywood and cut out just the states and leave it all connected to the original plywood if this makes sense… Where I got stuck is when I outline the USA, there is two outer perimeter lines so it would cut the entire thing out which is what I want to avoid.
Any assistance is much appreciated.
Thank you.
