I often use the probe to zero the machine but when I’m using the same material I will just quickly select “Use Last Position” under the manual zeroing window. I’m curious if that uses the zero from the very last carve, the last time I carved this workpiece , or the last time I used this project.
I often times bounce between different projects or if it didn’t cut all the way through I’ll duplicate a workpiece and delete everything I don’t want to re-cut and just want to understand how this feature works.
