Using a diamond drag bit with an excarve pro
hi guys,
I have an excarve pro 4x2 machine and would like to try some engraving on some brass trophy plaques. My question is how can i prevent the spindle from turning to do this operation or do i run it at slow rpm.
thanks Rodger
Youd have to unplug the spindle if yoh want it off and able to freely rotate.
Hey Rodger, did you ever give this a go? Was it a success? How did you set up the bit in easel? if that’s what you used?
