Above is my objective, a simple carve with 1/4" and 1/8" bits perhaps, 30" wide (x) by 16 deep (y). In summary, I have had my X-Carve running for about 10 days. I broke a few bits, made an acrylic dust boot, learned that carving through the clamps bolts doesn’t work (homing)…
I use Sketchup Pro 2016. Brand new PC running Windows 10, broadband internet. I understand the critical mission of causing a marriage between Sketchup and Easel. I’ve tried a few methods of getting my Sketchup design (above) to Easel without much success, likely due to my infancy.
Sketched in top view, 2D, parallel projection, exported a 2D graphic to PDF, then used www.cloudconvert.com to produce SVG. Results crashed the page time and again.
I’ve attempted the SVG plugin from flightofideas. Result is
I attempted to use www.makercam.com. Import and export seemed successful until I got to the action button on the Universal Gcode Sender. I pressed the button and nothing happened, or something was happening but running in circles.
Not sure if a can of Black Flag or Raid will help me. I tried to use the Easel site to begin my design, but quickly learned that I’d be better off building my casket. My forum waders are getting holes in them already. I am not finding answers that are working. Making attempts to force the programs and plugins to work are not getting me anywhere. What am I doing wrong?
210 SVG objects versus 2889 is still too big? Scale it down? Where and how?
I think I’m gonna watch a movie now, I the Lush Lovin’ Theater.
Looks like there’s a lot of detail. Depending how you have the bits, depth of cut, and depth per pass Easel has to figure all of that out and for complex things it takes a while or can crash your browser.
Haven’t ever tried that but was the design set to be bigger than the work area of the machine?
Weird. If you had the Gcode loaded into UGS and it was connected to the Arduino it should have started moving as soon as you hit send.
I tried bringing your image into Easel (Downloaded PNG, opened in Inkscape, trace bitmap, saved as SVG, import to Easel) but I’m not sure how you wanted it to cut? Are you trying to cut along the lines of the image, do you want all of those details to be raised?
Attached is the SVG I was able to come up with from Inkscape if it helps you any.
Here is my Easel project of what I THINK you’re trying to do. You may need to adjust settings and sizes and stuff but as is it simulates for me in a few seconds and says it will take 46 minutes to carve.
I kind of figured the amount of detail when I saw that big SVG number (2889). I read where someone else mentioned about it. The problem I had was that after using the flightofideas SVG plugin, it generated 210 SVG steps (or whatever they are called) and Easel still said it was too big.
No, the design was smaller than the work area. I even allow for half inch over.
I’m just a baby, just learning to crawl.
The file you produced with Inkscape is perfect! Thanks for that. I just downloaded Inkscape and will play with it for sure.
Yes when you export from flightofideas it exports in line segments not closed paths, depending on the project size you can fix it using join nodes or trace and weak
