I am looking to to make a cribbage board with the State of Wisconsin. Thought is to use the offsetter tool to establish a path inside the state, then use the offsetter again to run two additional lines at a consistent spacing for a total of three cribbage rows. Then using the holes on path tool, add the 61 holes per row.
The issue I am running into to, is that when the 1/8th bit is selected and the hole width is set to .126, the holes do not show up on the 3D model? Also what is the “Use Drill Points” in the Holes on Path App? It won’t let me import once selected.
Anyone have experience with this combination of apps?
