I’m trying to carve a logo for my garage. I’m a bit perplexed about why my sign carved with these dog bone patterns at the end. Is there a setting I need to change?
Any help is appreciated.
Here is a link to the file I used. I did import the logo part as an image trace.
http://easel.inventables.com/projects/jd1In0ETPDumwLQ1UHHskwhanks.
Your link doesn’t work.
What bit are you using?
How are you setting zero?
It looks like you’re cutting too deep.
It looks like my issue was I had entered a 90 degree bit, but I actually had a 60 bit installed. End user error for sure. Also, I ordered a Freud 90 degree bit but was delivered a Freud 60 degree bit.
I am going to shallow down to about 1/16 in using the proper degree bit and see how it goes.
I have no idea why the link doesn’t work. Thanks for your help.
Thanks! I had input the wrong bit. I thought I bought a 90 degree but it turns out it is a 60 degree.
