In Easel, what happens if I use a v-bit in place of an end mill?
The earth reverses direction. Lol
I don’t know why would do it. Can you please explain what you need to do so we can help you get it done.
Is there a reason why you wouldn’t simply set the bit selection to Vbit and then use the Vbit you want to use ?
Easel doesn’t allow use of V-bits. I’d have to upgrade to Easel Pro, a financial step I can’t afford to take. Thus, my question of using a V-bit when the system thinks I am using an end mill. What would the cut look like? I guess I could experiment with a piece of scrap wood.
