Im hoping someone can point me in the right direction on this logo. Ive been trying to V-Carve this out with my 90 degree v-bit, but when I click on “clear out pocket”, the Q, B and R fill in and won’t carve. Is there a way to eliminate the pocket that this creates?
Youd need to select all of the inside parts, set to 0 depth pocket and bring to front, all the rest should be set to a pocket of the desired depth and sent to back… once the layering and depths set to 0 for the holes you can combine them all together… the 0 depth on top will erase them from the shapes below…
