Have tried loosening all v wheels and readjusting them. But they all go back to the same positions. The spindle is tilted forward to much, not perpendicular to table. What are my options?
Shims provided everything else is good.
geez,
it looks to me like the axles (screws) are not tight enough.
If that is not the case, then the holed in your carriage are not perpendicular to the surface.
A lot of x’ers switched to axles here a long time ago. My machine has been set up with axels for at least 2 years with no trouble. I bet I can find the thread. Hang on.
Here it is. Old. Very old, and maybe there are better mods but this was super easy. And I think I stole the idea from @ChrisMeyers (could be the wrong Chris Meyers).
I’m having the same issue where my Gantry is tilted forward a little. X rail is 90° to the wasteboard along with the Y axis. Did you find a fix to this issue?
Loosen the four bolts on each end and rotate the beam. Bolt holes should be big enough for a little rotation movement.
Will do when I get off tomorrow. I figured that would be the best bet. I messed with the v wheels for a while but it was getting late so just left it where it is. Thanks for the help!
Take all the adjustment out of the eccentrics then tighten those angled wheels.
Then you can go back and adjust the eccentrics.
Do as Mark advised first. Get the wheels corrected before adjustments to the beam. The eccentrics should be adjusted so the wheels will not slip when turned with one finger, but will when turned with two fingers.
Take out the router from the mount and remove the belt before trying to correct the wheels and beam rotation. It will make it easier to make corrections.
