Vacuum Brush falling out of shoe
I have had several in incidence were the brush fell out of the shoe.
I came up with a fix that I hope will take care of the problem
I used 4 4x 3/8 screws. Drilled 3/64 holes, counter sunk and added screws.
I hope this helps others.
ca glue will do the trick. also, the brush should float just above the surface of your material
If you don’t need to change the brush
WOW! What a GREAT Idea!!!
