I am curious if any one uses these?
They seem like a great deal
thanks
thanks
Those are pretty cool, if I was doing any kind of production work I’d really be looking into them.
Doesn’t look to bad to build your own, here is the venturi they are using to build vacuum.
oh check it out yeah i have been debating on making my own out of Delrin but I am not sure if I could do it for that price
I wonder if I can get away with using pvc instead of delrin
I do know that alot of people do seem to be using HDPE but in my experience HDPE is not dimensionally stable especially when surfaced and with drastic temp swings
oh yeah I have seen those I would be worried about screwing them down to the spoilboard and cracking the plastic especially when its cold in the shop
although you could insert metal sleeves in the mounting holes
Check this out. I knew someone had these.
You da man thanks
I believe .125" diameter.
The tubing is .25" OD
oh okay thanks
Haha, I can tell you right now the channel is centered vertically and in between the inner/outer wall, so its ~.0625" deep.
oh wow those are small I might have to scale it up a little
but thats a pretty good looking design I am thinking
and thank you for the measurement
Yeah when i was designing it I tried to fit a 1/4" ring but my design didn’t have enough space for it and I was too lazy to scale everything up lol. Heres the .f3d
archive so you can scroll through history to change the dimension(s).
puck.f3d (161.4 KB)
lol no worries thank you for the file I really need to get on the ball with making these vacuum fixtures I bet they could be a huge help in the shop
better order me some sheets of pvc type 1!!
I’m all about using Vacuum in my shop for clamping. WIth the proper setup these units should work great.
I have tested many different types of gaskets but have found the Dstyle to work the best. It’s not cheap but does the job well.
I find it at LMII.com
Below is the part number
SPVACPG Vacuum gasket material for VWH
If you can find this cheaper, please let me know. I like to keep a surplus of this gasket in my shop.
