Looking at buying Vcarve Desktop or Pro and want to know if the upgrade is worth it or not. My biggest worry is the size restrictions. And can it send gcode directly to the Xcarve or do I have to use a separate program like easel or ugs.
You can get the Desktop version, then only pay the difference if you upgrade to Pro. That’s what I did. In fact, that’s what Vectric recommends. The 2nd project I did exceeded the 24" max. I also use the gadgets, scripting, toolpath templates, and Nesting.
Keep in mind, Desktop will allow larger jobs, you just have to do them with multiple tiled cuts. The size limitation comes into play when you are trying to do all of your toolpaths in one gcode file. I did a sign that was 6 feet long in 3 seperate cuts which is easily facilitated with the toolpath tiling function. Desktop will also actually allow you to go up to 25"x25", and you can also cheat it up to 26.5 if you use the largest tiling overlap and only cut the first tile. Ive used this method on multiple occasions.
Keep in mind that cost all depends on where and when you order it from. If you buy it from their website, it will cost you $350 more to upgrade to Pro. If you buy it from Inventables at the time of your X-Carve order, Pro will only cost $175 more.
