Vcarve gcode importing
|### Dominic Seymore ds2mobilesolutionz@gmail.com|4:00 PM (30 minutes ago)||
|to support
Hello
I"ve been using the vcarve software for a few months now with no issues when importing to easel as an gcode. Recently I’ve had trouble with the placement or where the vetor shows up on my post processor. The preview tool path is correct but once imported the design coordinates change. Can someone please assist with this?
Thanks Dominic
images of issue would help.
Sounds like some incorrect settings within the job setup in vectric may have been selected, such as “offset” under the x,y,z position setting.
OR the incorrect post processor was selected as only the “EASEL” one generates the correct gcode needed to run within easel.
also, I’m not support, but you posted into the public forum, so you will receive public replies…
