I need to cut on some Cumaru. Also called Brazilian Teak. It is super hard (3500 on the Janka scale) and I am looking for some advice on cut settings. I usually cut “common” woods and have not had issues selecting from the drop down menu choices. I don’t have extra material to use to play around with settings. Nor do I want to snap bits trying blindly so I am hoping someone has used something close to help make suggestions. It is similar in hardness to Ipe and Brazilian walnut if that helps.
Please and thank you!!
