Any help would be appreciated. When I go to cut my project it is making the shapes like 4 times bigger than they are supposed to. It even goes to the rail when I go to cut. I have no idea why. I loaded the machine as other, I have the right working space and have the 0 axis points set before cutting. It has a GRBL controller but not sure if I have to do anything special for that. If anyone can explain or reference me somewhere you would be a life saver. Once I get this solved I should be good to go,
Do you have it set correct for mm or inches?
I have it in inches
