WAY off path, broke a 1/16 bit!
Not sure what happened here, but below are two pictures. One is of my project in Easel and the other is what happened when Carvey went to execute the project. Everything was fine up until the last 10% or so.
I had an outside path set to cut the project all the way through but on that final pass it just decided to go off on its own. It was only running for approx 20 min to cut this, any thoughts??
Thank you in advance.
-Ryan
@RyanLockhart This video may help, basically the homing button is ~.03" too low, so the initial cut is too deep and can cause so much resistance that it will go off path or break a bit. We show how to fix it pretty quickly.
