Why am I getting these ridges or steps (not sure what they are called) on every layer of the cut? Using a 60 degree bit and have the same bit selected in easel
Welcome to the forum
Does your V bit actually go to a point or is it have a flat spot on the tip.
It is the 60 degree vbit from the inventables store, it is a point
I think the V-Bits from Inventables (at least the last time I used one … never again … the bit snapped off of the shaft) are not actually true-point bits. They have a very small flat tip, but the standard Easel setup accounts for this I believe.
Can you share the project publicly just so that people can make sure nothing is amiss there?
{:0)
Brandon Parker
@BrandonR_Parker i am away from the workshop, it was every thing I have carved lately, would this be the vbit step over or the other setting when generating gcode?
