What would be the best feedrate and depth for these bits? Where could I get higher quality 10 degree engraving bits?
http://www.amazon.com/gp/product/B00EQ1WI2C?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01
The 10 degree vBits are pretty fragile so I would keep the feedrate under 25 ipm. I have found that the 30 deg vBits are about the smallest vBit I need, even for very small text carving. And even for small text I usually can use a 60 deg bit that is super rugged as long as I don’t need really deep cuts.
I’ve had great luck with toolstoday.com
Flexible system
http://www.toolstoday.com/p-6009-in-groove-cnc-insert-engraving-tool-body-replacement-solid-carbide-insert-knives.aspx
The first bit here is awesome
http://www.toolstoday.com/p-6400-solid-carbide-spiral-cnc-2d3d-carving-tapered-and-straight-flat-bottom-end-mill-zrn-coated-router-bits.aspx
Okay, I was trying to do something like this, but information is a bit lacking, like the tool he used and the settings he used.
You can use a .125 ball nose bit or even a 2 mm tapered ball nose.
In general you are going to need a .25 ball nose to do the first rough cut. Then the .125 ball nose for the detail cut.
For most 3D carvings that works very well. If there is a lot of very fine detail you can do a second detail pass with a 30 deg vbit.
