I’ve been trying to find a diagram for the 1000m waste board, and the drag-chain bracket that does NOT go on the gantry. I’ve clicked on the links for both the 500 and the 1000mm boards in the assembly instructions (down in the "work area"section) and I get “you don’t have permission” even though I’m signed in.
I went through all the pdf files in grabcad, had to because the titles are just numbers with no idea of what is behind them. I did not find a 1000mm wasteboard. I found an 18" one. My metric conversion is lousy. I’m not sure if 18" is 500mm or half a furlong, but I’m sure it’s not 1000mm.
And I need to know what drag-chain bracket will go on the side, not the gantry. I made one today for the gantry (looks like pdf 14058). I thought I had the plans for the side one - pdf 14054 - but then when I read the instructions they showed something entirely different.
Help with one or both of these would be appreciated.
Thanks again. I saw the 14059/60 when I was going through the pdfs, but they just said angle bracket and I was looking for “XXX drag chain bracket” since that’s how 14058 was labeled.
At least they look like they’ll be a lot quicker to make than 14058 - just a few holes and a bend.
