Check your G Shield connection. If that is good pull your Arduino and run Blink from the Arduino IDE program. If that works you may have to reflash your board with the bootloader, check forum for bootloader
tried l\blink ,got error
tried bootloader ,cant find usb device
Got another Arduino sittting around, you may need it
i ordered one ,what could i have done wrong?
ardurino or gshield or both?
Maybe spike voltage from something
In order for the machine to connect it needs:
- installed and working device driver software
- good quality USB cable connected to a working port
- Comm program w/ correct settings
- Arduino which has Grbl installed and functioning
- gShield in working order
Check each aspect of the chain to see whatās wrong. Fixes:
- uninstall and reinstall driver
- try a different cable or port
- check settings or try a different program
- re-flash the Arduino, clear the EEPROM area
- check gShield connection, test gShield
Iāll repeat my earlier question: What version of grbl are you using?
Thereās a difference in baud rate going from 0.8 to 0.9 - 9600 to 115200
Im not sure ,for now Im waiting on the new arduino board
I did try both baud rate settings
Sorry you are having trouble @DanHenry Have you been in contact with Inventables customer success team? They can walk you through getting it fixed and replacing any defective parts free of charge.
No, Iām not worried about that ,it worked when I got it .
I ordered another, and I will give it another go.
I get frustrated but I donāt give up,
Flashed the arduino ,itās working again!!!
Iām using GRBL latest build
Yay!
What does it mean to flash arduino? I know what the arduino is (I think). What is it to āflashā it?
Hi everyone. Easel is good for 2.5 d image. Which software do you recomend for a 3d object. I wants to work with wood and also aluminium. ?
Thanks. Iāll be giving a look. Is this something Iāll have to do before I can use my new machine, or is it predone at the factory the first time?
If you get a machine now, it will not have an arduino. The new machines use the X-Controller.
I see. So learning about flashing the arduino is rather a moot point, eh?
I have window OS on my laptop and I have faced the same issue which I have solved with help of hp touchpad not working. So You can ask you here with your problem like me
have you run machine setup in Easel?
