We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youâve provided to them or that theyâve collected from your use of their services. Learn more.
Hi. I am mounting my first X-Carve and I am already thinking for enlarge it.
I have de 500x500 model and I would like to enlarge the X axis to 750mm. The problem is that the taxes and shipping cost for only this piece to Spain.It will be more than 100$
Anyone know if is it possible to buy it in Europe?
Or maybe someone knows an alternative with more common profiles?
Thanks for your quick response. I will investigate about these profiles to see if they are compatible.
One solution that has just occurred to me and I have done a quick test would be to use two Makerslide profiles (Y axis). I would only have to join them with a 4.15mm gap. And the best of all is that they sell them in Spain!
This was the original set up as stated above. There is good reason inventables moved away from the design. You will more than likely spend more than $100 trying to get it rigid.
Try robotsavy thatâs where I got mine in the uk. Great guys just give them a call with anything you want off Inventables website. They will add it to there next order and let you know when itâs in. They usually do a big order every 2 weeks.
