Will Easel + X-Carve attempt to carve outside of the material dimensions?
Just curious if I have a I have a large design (say 24x50) and I plan to do it in two different cuts, so I need to clean up the work space so that there are not things outside of the working area? Or will it only attempt to carve items that are inside of the working area?
Thanks in advance,
Brian
Hey Brian…
If its outside the work area… make certain it is zero depth. Then you’ll be fine…
Run a simulate just to make 100% sure…
Just re-read your post. If its all one picture that you are dividing into 2 cuts… you could cover it with a square or circle as above… just put the square over the half you don’t want to carve and zero…
Another illustration to show what I mean…
Good luck…
This is an example of what I am talking about. But I think you suggestion would be easy enough. Whatever I have outside of the working area, just toss a 0 depth box over it…
Bingo !!
