I am not a Profi and using my xcarve not very often, but I realise since I try to use to since two months that the Zero probe option is not a screen which I can select during the carving process .
I am right now manually bringen the router bit to zero , but what is the mistake , that I cannot see the screen where I normally attache my cables and put the Metal piece under my router bit?
What Andrew said, well kinda because there is a slightly easier method now … a while back they did an update making it easer than re-doing the entire machine setup like you had to in the past to get that probe function back.
You can go to Machine>Edit Machine and there is an “accessories” section and you can turn on the Z-Probe option. Make sure to save to Exit and you should get the Probe Z option on the next carve
