I have just got a second hand own built CNC. I set it up in Easel and had to use the set up process to reverse the direction of all the motors as they were wrong. it then worked OK. Today i realised the machine had been wired up with reverse polarity which i corrected. The problem now is all themotors turn the wrong way again ( not a suprise ) but when i go into machine on Easel the page to disconnect current device does not appear so i cannot get into set up ( set up new machine ) as i cannot remove current machine. Any ideas please?
just clear your browser cache and history and try again, this should do the trick
Thank you so much Ken. Worked straight away.
Yes, that Ken is pretty handy to have around. Pretty smart for a German Shepherd.
