I’ve moved to Mach 3 and am setting up limit switches for the first time.
I also implemented the x-axis improvement with the single piece large extrusion.
when you do that you need to flip the switch, which I DID NOT DO before I put the x-carriage back on,
meaning that when I unscrewed the little teeny bolts to flip the switch, the even tinier nuts came off the bolts and now I have no realistic way to get them back on without tearing the machine apart, which I am not about to do.
So my question: any tips on ways to attach the x-limit switch to the x-carriage so it will stay on?
Crazy glue? super magnets? what do you recommend?
Glue might work, but I would think that with a mechanical switch you would get some movement during contact with the moving carriage.
If you still have the nuts, I would tack glue them to something like a popsicle stick and then use that to position them inside the carriage while you put the screw in from outside.
I used a drop of hot glue on the back and then hit it with the heat gun to promote the bond. Worked like a charm. Then used a bit of extra around the switch to hold it better being careful not to get any in the moving parts.
I drilled an m3 hole once and tapped my custom gantry plates with it.
now i would probably just move the switch redrill and tap m2 and then bend the lever arm if needed.
Or mount them on a piece of Nylon which can be bolted with M3 and locknuts to the gantry. The plate extends, in case the switch does not stop the motors in time the plate protects the switch.
By the way, the latest X Carriage drawing shows these holes as tapped now. I don’t know when they rolled that change in there but when I bought mine last year, they were not tapped.
the needlenose pliers did not work for me,
the nut kept slipping to a bad angle.
What I did in the end was use a small amount of scotch tape to fix the nut to a popsicle stick,
and hold it in place that way while I turned the bolt.
Worked quite well, and the popsicle was pretty good too.
Thanks everyone for all your help.
It is really appreciated.
