I’m having an issue with the X Axis pausing during cuts. Not sure if it’s losing steps or if the motor is bad or a million other things. I’m having circles come out as ovals, and random starting and stopping when the router is cutting along the X axis. Is there a procedure to test the motors to make sure they are behaving correctly? I vacuum and air hose off the machine between runs, belts and v-wheels seem to be correct. I’ve only started having this issue after my first dozen runs or so.
X axis current adjustment too high or too low, would be my guess from the description
Video has been fixed, Thanks
