X-Carve 1000mm Pre-11/2021, w/ upgrades - ATLANTA, GA
This machine is in excellent condition, and has a number of upgraded features. It has the sturdier steel rail risers and stiffeners, for added stability while in operation. Those, along with the now installed 9mm belt and motor kit (improves movement and cutting performance) were all purchased from TBD CNC, who are now owned by Inventables. The base of the machine has been reinforced with additional aluminum cross bars. The wasteboard is stock, but has been mounted with spacers to ensure the surface remains level with the side rails. I’ve also added a removable T-track compatible working surface that is fitted with guidebars to ensure that materials can be mounted square with the spindle path. Comes with dust collection, wasteboard clamps, and Z-probe kit. I’ve also fitted a custom guard over the wire connection area on back of the X-Controller. I’ll also include a set of 17 router bits, normally sold separately.
$1,600 OBO
Local Pickup ONLY
This item has SOLD
