For Sale ~ Completely Assembled X-Carve 500
See it running a plotter pen test here ~ https://drive.google.com/open?id=0B0RDKYEUhVKCNFNCdUF4S2lrVDA
X-Carve Specs
500mm X 500mm waste board
X-Carve 300W 24VDC Spindle Kit 24V 300W spindle
X-Carve ACME Lead Screw Kit
X-Carve Power Supply Kit
X-Carve 500mm Wiring Kit
X-Carve 500mm Drag Chain Kit
X-Carve Clamp Set
X-Carve Limit Switch ~ both Min and Max Switches (standard X-Carve has just the Min Limit Switches)
Set up for Z-Probe and for Bed Level Compensation.
Y motors are set up on the SmoothieBoard to each have their own stepper driver ~ no parallel connection of the Y motors!
A few other mods/improvements ~
Controller Board ~ SmoothieBoard 4X $120 ~ smoothieware.org
SmoothieBoard gives you smoother more precise movements ~ much more powerful processor than Arduino etc…
SmoothieBoard can be controlled by Pronterface or OctoPrint/Octocut ~ Standard GCode ~ SmoothieBoard is very supportive and there is an active and helpful community.
Nema 23 Stepper Motors ~ these are industrial motors ~ more durable and quieter. (not the stock 23 from Inventables).
Y Drag chain is oriented vertically so the X-Carve takes up less desktop space ~ vertical drag chain works just fine.
Fixed the problem with slipping belt clips.
Include a chip blower set up ~ a hose on a gooseneck attached to a pond air pump ~ pretty cool! Included at no extra cost.
Also included ~ A couple sets of 1/8” bits $100 value!
From Drillbitsunlimited.com
V Engravers: 10, 15, 20, 30,45,60, or 90 Degree (45 Degrees 0.10mm tip, One Piece) V Engravers: 10, 15, 20, 30,45,60, or 90 Degree (30 Degrees 0.20mm tip, One Piece)
V Engravers: 10, 15, 20, 30,45,60, or 90 Degree (60 Degrees 0.20mm tip, One Piece) Two Flute End Mills Limited Time Special! (.045" 1.15mm .200 Flutes) Two Flute End Mills Limited Time Special! (.050" 1.25mm .250" Flutes) 1.00mm .040" Ball Nose Two Flute Carbide End Mill (One Piece)
2.50mm .098" Ball Nose Two Flute Carbide End Mill (One Piece) 1/8" 3.175mm Ball Nose Two Flute Carbide End Mill
From Bitsbits.com
Wax Cutters Starter Kit (Bits)
- Profile tool 10inc angle .003 - perfect for fine detail
- Profile tool 15inc angle .003 - all around favorite
- Profile tool 15inc angle .005 - A bit stronger than the .003
- Standard Ball End Mill .032 - Used for milling & profiling
- Standard Flat End Mill .125 - true up the surface of your mold
- Standard Flat End Mill .062 - Used for milling & profiling
- 4oz Bottle of Soy Cut Oil - Excellent for clean milling and lubrication
Price ~ $1000
plus shipping ~ estimated at around $50 (may be more or less)
