X-Carve Bit for Machining Fillets
Good evening All,
I’m after some advice on which bits people are using to machine fillets?
Or could somebody offer some advice on how I would go about machining this?
Thanks.
For an interior edge end mills and ball nose bits will naturally create a fillet equal to the radius of the bit. For a fillet on an interior edge at the bottom of a piece, a ball nose bit will do the job, the fillet will be the radius of the ball nose.
For exterior edges, you will need to design your part with a rounded fillet. The same applies to interior edges where your fillet radius is bigger than your bit radius.
