I have an SVG cut file that was generated in Adobe Illustrator and imported via Chrome, also I’m on a Mac. I’ve run dozens of files and for some reason the software is forcing the solid shape, set to a “fill” cut, to cut as an “inside-outline”.
The SVG file is RGB, solid and we have used this identical file multiple times with fine results. The same thing happened with another file, so it seems to be software. Was there a recent update I may be missing? I reworked the file, uploaded it again, restarted the browser and emptied the browser cache.
Very weird, very frustrating. Thanks in advance for the help!
brandon
