I got my hands on a some stepper motors that I would like to use mon an x-carve.
I am currently running the stock motors with an x-controller.
The motors are heavier at 1.4kg, will this be an issue?
They are longer. So at the moment I wont be able to use them for the Z axis. Might consider upgrading to the cnc4newbie direct drive for z.
They have an 8mm shaft so I will need new pulleys, I am thinking I will upgrade to 9mm belts as well.
The wiring connector is different, I think I would rather run new wires over cutting the existing ones.
is there somewhere I can see read the specs for the x-controller and what motors it can support?
I am hoping someone can weight in on if they see any issues with these motors?
Motor details
Sanyo Denki - 103H7823-5740
1.8°/step
Holding torque at 2-phase energization [N·m (oz·in) min.]: 2.7 (382.3)
Rated current: 2
Wiring resistance: 2.4
Winding inductance:9.5
Rotor inertia:0.84
Mass (Weight)[kg (Ibs)]:1.34 (2.95)
Motor length (L): 85.8 (3.38)
Shaft Diameter: 8mm.
data sheet
Appreciate any insight you can offer.
