Will the x-carve pro cut edge to edge on a 4’x8’ sheet of plywood? Wanting to cut the side walls of a teardrop trailer that requires a cut from zero to 47.875” on the x-axis. The y-axis would need to be tiled.
The XCP X-axis limits are set to 48.5657"
So if you’re using a 1/4" diameter bit or smaller than the bit can cut up to 48.1657" making the answer to your question a yes.
