Even thought I received the T Track parts a month or so ago, I’m finally between enough projects to get to installing.
In the XCP T Track install instructions video, at ~ 00:30, Brandon says to use socket head screws, but the install video is showing button head screws. I’m going to make an educated guess that socket head screws are used here, since they have lock tight on the threads.
Later in the video, the waste board is attached with ‘ball head screws’ (assuming button-head).Hear, Brandon distinctly calls out 3mm screws, so that identifies the button head screws.
Just wanted to make sure my selections are correct.
