I just assembled my X-Carve upgrade. When I got it all hooked up, I love the solid Z-Axis and the bigger belts and all! Everything ran smooth for the first couple test cuts. now it is grinding during the probing. The machine is also not cutting the depth or the size hole I am trying to cut.
Did you go through the setup process or otherwise update the GRBL settings to what they should be for the upgrades installed?
{:0)
Brandon Parker
The direct drive “Z” no Belt loop dose make much more noise. the belt absorbs most of the noise.
if you increase “Z” travel speeds it will make a little Quiter.
