Purchased base machine August 2020. Since purchasing the Xcarve, I’ve added virtually every upgrade that was available for this machine including the taller Z-axis gantry, stiffer maker slide, taller risers, 9mm belt upgrade kit, bigger stepper motors, side stiffener panels and modular waste board kit. I also replaced the palm router that came with the unit with a spindle kit (spindle, controller and dust boot system - $1190) from PwnCNC. All told I have roughly $4450 invested in this setup. I will take $2500 for the entire thing. You need to provide your own platform to mount it on. I’m switching to a different CNC as I’ve outgrown the limits of this machine. Located near Boise ID.
