XCarve moving in wrong direction with Grbl controller
Hi,
I am trying with Grbl 3.6.1 by Zapmaker as my controller. I zero the bit but once I start the carve, the X-Carve shoots off to the distant corner.
I saw that BadWolf mentioned something like this sometime ago, but do not know if a solution was found.
I have tested with Easel and it works perfectly.
Any assistance would be appreciated.
Thanks
Steve
When I encountered that w/ Grbl Controller, it was caused by an unsupported G-code:
I believe that Easel does some filtering of G-code so as to avoid this sort of thing.
