This has to be a stupid question. I have been using my XCarve for a month with no issue. I got it as a used 750x750 machine. For the first time I have tried to use nearly the full bed of the router and it is showing a 350x350 box on the bottom half and is only cutting the bottom half of my design, not going past the vertical midpoint (375). The setup is configured at 750x750mm and the full wasteboard is showing up with the top half of the design configured to cut the same as the bottom half.
What stupid thing am I missing? Thanks.
