Does any know the wiring configuration from Xcarve upgrade motors to Blackbox X32 controller??? I currently have them as white-red-green-black
did you see this about 31 minutes in
OpenBuilds WorkBee 1010 and 1050 Electronics and Software (Using BlackBox) (youtube.com)
If you have an ohm meter you can check the steppers for what pairs are what colors on your current motors.
I do not have an ohm meter
And this machine is different than mine - I literally need an exact match to follow as I am not that technical
Buying one now, thanks!!
