How can I reset the Xcontroller back to factory settings. I tried to install LightBurn and can’t get it work. Now in Pic sender laser mode, the Xcarve runs in the opposite direction.
The direction of movement is altered with the $3 setting.
You need to read the current value and then adjust per the chart.
For Example, you cnc is running X backwards and is currently set to $3=3
You would select the option that only changes the X value, but keeps the Y and Z the same. The New Value to use is $3=2
Thanks Seth. Where do I find the table that you referenced?
I added the chart as a photo (maybe its not showing on your device), but here it is as text:
& for this purpose you can ignore the “Mask” column
Setting Value | Mask | Invert X | Invert Y | Invert Z |
0 | 00000000 | N | N | N |
1 | 00000001 | Y | N | N |
2 | 00000010 | N | Y | N |
3 | 00000011 | Y | Y | N |
4 | 00000100 | N | N | Y |
5 | 00000101 | Y | N | Y |
6 | 00000110 | N | Y | Y |
7 | 00000111 | Y | Y | Y |
and a link to the grbl settings github page where it’s also posted:Grbl v1.1 Configuration · gnea/grbl Wiki · GitHub
