y axis end plates
Note: You want to make sure that the rails of the Makerslide are on the flat side of the end plate and that you leave one hole open on the top side of the end plate.
Hi guys, still having a problem with the y axis end plates and I cant get through to inventables as I am based in the UK and having trouble. As you can see in the instructions it states that the rails of the makerslide should be on the flat surface of the end plates, so this should mean that two of the plates mirror the other two when laid flat but this is not the case. I cant really move forward with the build of my x carve HELPPPPP!!!
