I could use some troubleshooting help.
I have done 3 carves since the machine was set up. First one (the hello world demo carve) had a Y-axis anomaly and was aborted; mid way through the carve, after a few depth passes, the Y-axis was off by an inch or so.
2nd progressed but I had easel issues with the smiley face (not cutting the eyes, might have been a problem with combining curves), and seemed to have a z-axis depth of cut a bit deeper on the first pass than expected - which I have not tested again yet.
This 3rd try was the Fletcher clamps, and I thought it was fine until suddenly (while I was pre-occupied with vacuuming) the y-axis moved 3 inches. You can see in the photo if you’re familiar with the clamp design.
It homed to a position almost exacly 3 inches back from the origin, when I hit the Cancel icon in Easel.
What could be off and what should I try next, to fix this?
Looks like you might need more current to your Y axis
See here for more info:
[Solved] Cutting wrong, loosing position
Other than that, make sure that your V-wheels aren too tight or too loose.
Thanks! I’ll give that a shot tonight.
just a quick note on adjusting the stepper currents: Do not just turn them all the way up as this will hurt the steppers. follow this guide: http://rigidtalk.com/wiki/index.php?title=Stepper_Driver_Adjustment
yes it is for 3d printers but same concept and method!
Agreed. In the link I provided the information there talks about the same. Only turn it in small increments and there is only 270 degrees of movement on the gShield pots.
I adjusted the trimmer pot and used the jog controls from the machine setup to confirm, old setting if I hit Y jog several times in a row it skipped, turned the pot a tiny bit clockwise and tried again, no stutter. It’s been doing some flattening for the past hour on maple with a 1/4" end mill and has not skipped a step yet.
Thanks everyone.
Perhaps this should be part of the assembly guide?
At least in the tuning section
