I cannot work out why, but after a few cuts, when i measure the distance from y1 to the left brace vs y2 to the right brace, the y2 motor is always further away by 2mm ish?? i move it back so the distances are the same and it keeps happening? I have already tried
Also, Have you tried carving a square at it’s naturally relaxed position (2mm back) does that still form a perfect square? Does forced to be aligned carve a perfect square? (i recommend this test using a v bit just barely carving into the surface of a MDF board and measuring diagonally corner to corner to check for square) IF the natural position carves a better square than the brought forward then I would stop forcing it forward. . . If the forced forward one carves better then you can measure the frame of the cnc diagonally, and then use those measurements to assist in adjusting it by loosening the frame and then altering the shape to get the diagonal measurement into the desired position, tightening back, checking the gantry natural relaxed position. . .and then re-running the v bit carving just to verify.
