Excuse me if I am in the wrong Forum, I am fairly new to this.
I have a problem with the bearings in my x-axis falling out all the time. Is there a good secret someone could help me with outside of super glue?
Hey Garry,
what type of cnc is this? X-Carve?
and do you have a photo?
thanks!
It is a Genmitso 1810 Pro
I am attempting to put a photo here now. I am not as smart as I used to be so if you would hang on, I would appreciate it. Thanks.
Ok, I see.
I thought this was the 3018. Its a pretty common issue.
They are press fit into that hole. Mine have never come out, maybe I got lucky.
I’ve seen people add CA (super) glue and press them back in.
And I’ve seen some remove them, drill and tap in a set screw and that seems to work as well.
I think the glue method would be easy enough to try
Thanks. I think I will try the super glue. Have a great day and stay safe.
Here’s an old tool & die makers trick.
Take a large ball bearing (obviously larger than the hole). Place it on the hole, then give it a rap with a hammer.
What this does, is puts a slight chamfer on the periphery of the hole causing it to close up slightly.
Works every time.
We used to take a center punch and tap it a few times around the outer bearing and give it a slight burr then tap it in place.
Yep…that will work too.
