Hey guys. I just upgraded my X-carve 1000mm with the new upgrade kit, containing the X-controller and all the other good stuff. My machine worked flawless before the upgrade, but now the Z-axis doesn’t cut deep enough at all.
If I set the distance to 10mm in Easel, it travels approximately 2mm in the Z-axis. The X and Y-axis work flawless. I have configured the Z-axis as a ACME rod, and tried to configure it as a M8 instead, however without that working correct either.
My machine inspector looks something like this:
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=115 (status report mask:01110011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$30=1. (rpm max)
$31=0. (rpm min)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
What am I doing wrong? I have tried the Easel configuration many times, however it doesn’t change anything. I hope some of you knows what to do
Thanks!
