Is there a way to control the height the z axis will raise in-between moves? I’ve been trying two stage carvings but I’m running into an issue in the second stage when it will not raise high enough and create lines. This happens mainly when doing letters. The 1/8 bit will clear out the bulk of it but the 90 degree v-bit will create lines across the bottom of them. Any help is appreciated. Thank you
You can set the z height in machine , advanced , zheight.
Thanks Wayne! I will give that a try.
You will need to reset it for each project you do but it will stay where you set it per project.
