trying to figure out why my machine jogs up when trying to go down and down when trying to go up on z-axis didn`t change anything just started on a new carve any help would be appreciated.
Some how wither the $3 setting got changed, or your wires got swapped within the connector… obviously the first option is the most likely as easel is known for changing these settings when it shouldn’t.
You can go to machine >general settings > machine inspector and read the current value for $3 and then use this chart to make keep X,Y their current value while only changing the Z value…
